Hello team,
When trying to add cue points, the waveform is not visible in portrait mode.
Can we make this possible?
@LaidbackFred, switch from Classic Mode to Pro Mode and the detailed waveform will be visible in portrait mode.
Hey @Slak_Jaw ,
Easy on that solved switch. ![]()
Some of us user always has it on classic.
Well, maybe it only exists for me.
I’ve been into this mixin stuff since 1982, a bit grey there.
I need my vinyls:pray:![]()
How can one not want to stare at this view?
@LaidbackFred I’ll forward onto the dev team to consider adding a detailed waveform display, while in single deck, portrait, Classic Mode. In the meantime, you can use the suggestion above. Thanks for the clarification and suggestion.
