- Device model Custom PC Build (i7-13700, 3080ti, 32GB DDR5) :
- Version of operating system: Windows 10:
- Version of djay: 5.1.8217.0
Summary of the issue:
I’ve noticed that one of the waveform zoom modes doesn’t work properly and only displays part of the waveform which makes this mode pretty much useless. On top of that the order of zoom levels is wrong if you use the + and - buttons to change it.
- Djay Pro has 6 levels of waveform zoom. Go into the waveform zoom settings, and click the ‘-’ button until this option is no longer active. Let’s call this zoom level 1/6 for clarity. Now. While doing this you probably noticed something strange. Click the ‘+’ option again and the waveform becomes more zoomed out instead of zoomed in. Each subsequent press of the + button works fine so it’s just a problem with the 2/6 option.
I actually like this level of zoom, I like to see more of my waveform, especially when i’m not very familiar with a song i’m playing, but sadly that’s not the only problem with it.
- Only part of the waveform is rendered in this mode which makes using the 2/6 zoom level quite pointless.
How to reproduce the issue:
Explained above ^
It seems to me that the two problems are related.
It would be nice to have a properly working heavily “zoomed out” setting like this so I hope it won’t be too difficult to fix. Thanks!
