My DDJ-Wego3 Lightning Cable is broken. Can i also use it with the APPLE LIGHTNING TO USB 3 CAMERA ADAPTER on my ipad? And will it work just like with the normal special Pioneer ios cable?
Hi
You can alternatively use a Lightning to USB 3 Camera Adapter but that way your iPad wont be charged.
Alternatively you can also use a powered USB to Lightning Cable in order to also charge your device.
Cheers,Lukas E.
