Weird behaviour when disabling autoloop
Hello,
I am using a Rane One with 5.2.1. My problem is simple, but infuriating:
If I disable an autoloop close to the end of the loop, the track will still loop back to the beginning of the loop. I have already disabled the “always quantize loops to beat” option. “Quantize cue/loop” is also disabled.
Thank you.
Hi @Fangio, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Also, can you please try to capture a video of this, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? As I don’t currently have access to a RANE One, I’ll need to share this with engineering to see if they can replicate it. Thanks!
Device Model M1 Macbook Air
Version of operating system Sonoma 14.5
Version of djay 5.2.1
In the attached video, I am going to demonstrate two issues, both of which seem to be software-based and related.
First, you will see me activate a loop, then cancel the loop slightly before the end. You will see the loop reset back to the beginning regardless.
Second, you will see me attempt to tighten a loop down from 4 to 1/8. You will see that once it gets down to 1/4, it appears to take the software an extra loop to realize the change.
Please pay close attention to the mouse and when I am clicking in the video. I understand that issue #2 could be up for debate as I am cancelling/modifying the loop right at the end, but I absolutely cannot see how issue #1 makes sense as I am cancelling the loop before the end. Note that it doesn’t seem to matter whether the loops are quantized or not.
Hi @Fangio, thanks for the additional details and video. This is very helpful. I’ve passed this onto engineering for review. I’ll report back when I have news. Thanks!
This bug I can also confirm. I use an iPad Pro M1 and with my Pioneer Rev-7. Since the Update 5.2.1 the App doesn’t run smoothly as usual :confounded:
Thanks for the info @phuongtastic. I’ve passed this onto engineering as well.
Hi @Fangio and @phuongtastic, can you please confirm if this happens with Key Lock turned OFF? Thanks!
Aha! This appears to be precisely the issue. With key lock ON, I notice the mentioned bug, as well as various other critical delays (e.g. non-instant response time when using beat jump as well as when bringing stems in/out). With key lock OFF, at least after a few minutes of testing, none of this delay/lag is noticeable.
Thanks for confirming @Fangio. This is a known performance limitation when using Key Lock. Engineering is investigating options for improving this latency when using Key Lock, but for now it’s about 100ms.
Ok I’ll stay tuned. I’m sure you’ll agree that the delay is pretty much unacceptable from a usability standpoint for any complex routines/mixes which use the affected features. As well as from a performance comparison standpoint vs. Serato for example.
Oh yeah I can also confirm this bug when the KeyLock is turned off. Maybe I think it depends on the settings or mapping of the Rev7 with djay app.
Hi @phuongtastic. To clarify, the issue only occurs for you when Key Lock is ON? Correct?
Hi @phuongtastic, I’m just following up on my question above from a week ago. You’re response was unclear. Please confirm that you only experience this issue with Keylock ON. Thanks!
Hey sorry for late response.
It happen again…why are the Loops there? Orange and Automatic…key lock off and on? Like the App is crashing and do stupid things :dizzy_face::face_with_spiral_eyes:
Hey, just checking in on any progress in this area? The latency with key lock on touches pretty much all the features I need to use regularly (loops, beat jump, stems), and thus makes the experience very frustrating and borderline unusable in certain situations.
Hi @Fangio, thanks for the follow up. Our engineering team is still investigating options here, but we don’t have any updates to share at the moment. I will report back here when I have news though. Thanks again!
Hello,
I really hate to keep harping on this, but I just noticed this issue so severely once again that I felt compelled to check in as we’re coming up on half a year since my last comment.
The scenario was trying to use the instant stem fx such as vocal echo out. If I press it right on beat, the echoing portion is way later than what is intended. This obviously sounds terrible, so the workaround is to try to press the button just enough in advance to anticipate the lag, which removes nearly all precision. Unsurprisingly, with key lock off it all behaves as expected.
I have no doubt that there are challenging technical issues to solve here, but I hope you’ll agree that if it looks and feels like a bug, it’s a bug, and when it affects virtually all precision features in the software, it must be fixed.
Also wanted to add a note of interest, which is that regardless of whether key lock is on or off, everything works fine when it’s just the software and no attached controller. So that’s promising perhaps? Let me know if the team needs any more info.
Cheers, thanks!
Hi @Fangio, thanks for the additional observations and details. This is very helpful! I have shared this with our engineering team. Sorry that I don’t have more news to share on this other than our team is actively working on this and it remains a high priority. I appreciate you continuing to push this topic and I will continue pushing this internally as well. I’ll share more news here when I have it. Thanks again!
Hello everyone, we made some performance enhancements in 5.3. Please update to the latest version and let me know if notice any improvements. Thanks!
For the full 5.3 release notes, please refer to the topic below. Thanks!
