Weird behaviour with Phase DJ (Windows 11 25H2)
  • Device model (e.g. 2020 iPad Air 4th Gen): Asus Tuf gaming a15 laptop
  • Version of operating system (e.g. macOS 14.4.1): Windows 11
  • Version of djay (e.g. 5.1.2): 5.6.3
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Rane Seventy/Phase DJ
Hi everyone,
It seems that the only way I can get Djay Pro to recognize and work with my Phase DJ is if I do not open The Phase Manager app.
It is very simple:
If I open the Phase Manager app, Djay pro will not offer me the Wireless option for controlling the decks. Phase DJ is connected via USB.
If I only connect the hardware without opening Phase Manager, Djay pro does recognize them, I can pick wireless and control the sound.
I have no idea why this is, and it is annoying because after 2-3 hours of play, the phase controller is trying to act out and starts drifting, which is a problem with scratching. Phase Manager has an option to recalibrate on the go by double tapping the controllers, but I cannot do that as djay pro won’t work with Phase Manager opened. I did install/reinstall and no change in that behaviour.
Serato does recognize them with Phase Manager opened.
Hi @Metaloid, welcome to the Community! Can you please confirm if you are running Windows 11 25H2?
If so, please refer to this help article:
Hi there, thank you for your answer.
I am on 25H2 yes, and I did have massive issues with the latest updates blocking the recognition of my Rane Seventy by djay pro and serato.
I did a fresh windows install and rolled back certain updates and Rane is working 100% now.
It looks like I still have the KB5077181 version installed. Should I uninstall it?
You’re welcome @Metaloid. Yes, uninstall it.
Hey thank you for the support.
I am unable to uninstall KB5077181 because I had clean installed windows and it came with that update.
I am trying to find a way to remove it.
You’re welcome @Metaloid. In this case I recommend you contact Microsoft Support.
Hi @Metaloid, we have created a how-to video for restarting the MIDI service on Windows. This has also been added to our main Help Center article:
Hi and thank you for your support. I could not uninstall the Windows update because I installed windows after the update release, so it came with it.
Also your vido instruction did not solve my issue because I could not find that service on my pc. Still, my mixer works and is well connected to Djay Pro so I will keep things that way untill microsoft releases a fix.
Okay, thanks for the follow up @Metaloid
Hello everyone, we released a supplemental update to Windows djay 5.6.4 on April 10 which should fix the issue where MIDI controllers are not detected. We added a small workaround which should ensure that the Windows MIDI Service is started on app launch. I hope that helps!
