What does the “Neural Mix Edit” output option do in Neural Mix Pro? Its icon looks like an equalizer. Is it attempting to improve the audio quality?
Hi. When active, that option will export the track at the volume levels you’ve set for each component. It’s a way of creating something like a beat-a-pella or reducing the drums so other components are more prominent.
It’s exported as a full track, not individual components.
Thanks for the response!
No worries! Glad it’s sorted.
