Device model (e.g. 2020 iPad Air 4th Gen):
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
You use to be able to manually speed up or slow down a track with a simple + or - minus with those buttons. They are no longer available in IOS. Why? they are super convenient when a track is only a little off and you want to lock it back in. I don’t like using sync so that was my go to.
One more question. Is there anyway on my iPhone where I can choose how the song list is displayed? I ask because I tag my songs in bpm and keys. I like to have them orderly in slowest to fastest A -G keys. The software doesn’t get the keys right lots of time (neither does mix in key) so I play piano so I know the key a song is in and tag it. But unfortunately I can only choose bpm or keys and it messes up both ways where one is off. Is there a way on iPhone to set them up on the list display exactly how I want them? If there is that option that would be great. Please let me know. Thank you.
Thx. Unfortunately I have 1000’s of songs in my drive and searching for new songs is not exactly easy. Hopefully in some update they include the option to organize the music folder list in our own order. I do my folders by the week I put it together so hopefully it can be something that can be implemented.
