what’s the best controller or most compatible to use with this app?
i use this on my mac computer mostly
No need to thank me :laughing:
You haven’t specified much about your requirements but I can tell you the Hercules T5 is the best among the budget range of controllers by a long way.
I don’t know about “best” but the reloop buddy and djcontrol ultra were built specifically for djay pro.
As far as I know only the reloop buddy can have the app switch app views when you switch pad modes.
More info needed.
  1. what is your budget
  2. do you like mixing 2 decks or 4
  3. are you into mixing with stems
This info will narrow down what controllers will suit your needs. Some controllers specifically are labelled to cater for stem control and some controllers are 2 decks and some 4 with varying budgets.
