I already own Djay2 and bought the in-app purchases (ipad/iphone).
Is Djay Pro the newer version? Which product should i be using on my iPad pro and why?
For what it’s worth, I would be using my iPad pro with the Reloop 4 Mixon midi unit.
What a helpful community, thanks for all your responses.
djay 2 and djay Pro for iOS are both complete djay softwares.
It depends on your general needs, which version suits you better.
While djay 2 is cheaper but perfectly working 2 channel software, djay Pro comes with more features like the video mode and of course with a 4 channel view.
In combination with the Mixon, maybe djay Pro would be the better option as you can use all 4 decks of the Mixon.
I have the same question.
