When will this improve?
I have used Djay professionally and this is what is not right with the software.
SYNC:
  • It is the worst of all the programs I have used, it takes several seconds to re-synchronize the songs again (1, 2 or 3 seconds).
  • It only allows us to “sync bpm + sync beat”. When will we have “only sync bpm”?
BPM
When will we have it with 2 decimals?
QUANTIZATION
  • Where is the option to disable it? It is very annoying.
  • We should be able to choose between: 1/2, 1, 2, 4 beats.
KEY LOCK
When used the hot cues are totally slow. They lose accuracy after several seconds of playing the song.
ECHO POST FX
The tail of the effect should stay there after applying it. The echo is cut abruptly when you stop using it.
They are the only things I don’t like about Djay. The rest is all perfect. When will they solve and improve it?
