Another fail for the iOS manual. Honestly I would not need to keep posting so much in this forum if the manual was just up to date.
Anyway. Where can I find info on the crossfader FX?
Thank you.
Thank you.
Hi @N_C, we have lots of additional information in our FAQ articles. You can search for various topics there. Please see the linked FAQ below for more information on CFX. Thanks!
O, thanks. That video is 10 months old. Surely it should be in the manual by now? The problem with manual not being updated, is when you just need a quick refresh on something. Instead you have to go searching on Youtube or post in this forum.
On a positive - Just had a play around with C/F FX such a great tool, don’t why you’re so shy about it.
In Settings > General > Crossfader FX > Sync Mode
What is this for? When/how might it be used?
Hi @N_C, with this set to
Ah ok, so selecting 2 would result in an instant consistent BPM sync (incoming matching live deck) and 3 would give you a gradual movement in BPM as you move the fader, right?
