Hi, I found a list of compatible mixer for DVS on macOS but not for windows. Is there a list somewhere?
Im interested in particular in the Numark Scratch.
Hi @PatriceCros, the Numark Scratch is supported on Windows. Please see below. I hope that helps!
My question is for DVS compatibility,
like this list for macOS
I ask for windows DVS compatibility.
Hi @PatriceCros, sorry, I should have been more specific. Yes, the Numark Scratch is DVS compatible and is plug-and-play with the Windows version of djay. Generally speaking, if a piece of hardware is supported on djay for Windows and supports DVS (in general), it should also support DVS on Windows. Also, I have asked the team to update the FAQ article(s) to include Windows DVS compatibility for better clarity on this subject. I hope that helps!
