I have just changed iPads (I use an iDJ Pro…everyone should), and I am having to analyze my library again. Shouldn’t this be happening automatically through iCloud? Yes, I do have Documents and Data enabled etc etc…
The data from the track analysis does not get synced via iCloud, only user-generated data. You should probably know that track analysis data is not that small and could potentially use up all your iCloud space if you have a larger library.
