The Pioneer DDJ-T1 is NOT natively supported by djay Pro, yet.
However, you can map any Midi controller yourself, using our MIDI-Learn feature. How to do this? You can’t find a full description here (don’t worry, it’s a really straightforward process):
Hello,
I’ve passed around an hour to make my DJAY PRO learn my MIDI DDJ-T1 and :
1 : Y couln’t find the Pre listen (headphone) option which is symbolised by the CUE upper the the Deck Gain
2 : I accidently clicked on Reset so I’ve lost all the settings I’ve just done :’(
I guess I’m not the 1st who need to configure it… So would someone be kind enough to share the file so that I could download the config to make my DDJ-T1 work with DJAY PRO … ???
Biiig thanks,
Best regards,
Germain
