I can’t figure out how to uninstall DJay Pro, like other programs. Am I doing something wrong? I downloaded it from the App Store.
As we’ve discussed via Email: In order to delete djay Pro, simply drag the app from the “Applications” folder to the Trash (located at the end of the Dock).
Ok, thank you for the help. I was dragging it from Launchpad instead of the Applications folder. Thanks!
There are still left over files in Library as well as AudioJingle midi settings. How do you remove these additions as well.
how do i deactivate the current app to be reinstalled in my new Mac? i cant find the menu for deactivation //
