I would like to see the match work better for the Rev 1, starts out great then after about 5 songs or more it will just stop. Im on the MacBook Pro with the new upgrade to Ventura
Hi @JMAC361,
Thanks for posting!
By any chance are you using djay Pro AI v4.0.12?
Additionally, does match still not behave as intended when your REV1 isn’t connected to your MBP?
*This sounds like it may be a bug so I will be moving this post to the Bug Reports category.
Still works for about 4 or 5 songs then stop when using your own library but will work a few songs more with Tidal playlist. Will do this with a controller or without and i do have the latest upgrade on the MacBook Pro Ventura version
