Hi ppl, I just installed Djay. Great Tool, but I need to route the output to Jack Router. I cannot see it, is it compatible?
Hi Fillippo,
Please open “Preferences” from the “djay” menu and go to “Devices”. Try selecting it there. If it doesn’t show up in the drop down menu then this means that it’s not compatible.
Ok, thank tou
