There seems to be so may bugs with theses apps that I’m sure this issue is the least of their problems.
Djay iMac vs DJay iOS List differently. Why?
Hi guys,
please understand that app’s like iTunes might not support all the functions they usually provide, if their api is used in other applications like djay.
Sorry for the inconvenience.
Hi Lukas,
“…might not…”??? Are you saying that in this case iTunes IOS API doesn’t include the same listing features that are available on the Mac?
Let’s say you’re saying that’s the case.
What’s the best way to organize the playlists I sync with my iPad so I can find them quickly on my iPad version of Djay Pro? I can’t believe this hasn’t occurred to you to share this.
David
On the other hand, if the iTunes API DOES include the same organization folders, etc. on the IOS platform… it should be a priority free update!!!
