I don’t have an answer for that, maybe it need to re-read the details on the file.
But I wanted to tell you that I used to use iTunes as my main library, but Apple discontinue iTunes.
I highly recommend moving to some other option because when you’ll need to do it quick, it’ll be hard.
So take your time and find something else that work for you.
I use Serato for my playlists and sync it with Djay pro.
[quote=“Fridmanator, post:2, topic:17996, full:true”]
[/quote
Have you tried re-importing the playlist/track after editing the star rating? There is no way for djay and iTunes to sync changes to file data and I believe that might be the problem in this scenario.
I’m looking forward to hearing back from you and have a nice day!
Yes, I’ve tried everything but there are some songs that just don’t want to know about the variations of the stars. The old evaluation always remains in Djay Pro. No it’s important. Thanks anyway for your interest.
