Schaffe es nicht eigene Playlists zu erstellen. Irgendwie habe ich die Befürchtung das es nur in der Mac Version funktioniert.
Oder gibt es in der Windows Version “my library”?
Über den Mediaplayer oder Groove Music schaffe ich das auch nicht.
Ohne eigene Playlists ist für mich die Software wertlos.
You can create new playlists in the Windows Media Player, iTunes, Groove or directly in Spotify.
All these will be synchronized to djay Pro for Windows.
Cheers,Lukas E.
Thank you Heiko, we pushed the topic internally with your request.
Cheers
This is not really helpful. As a DJ for Swing dancer I really rely on the BPM feature. Therefore, I organize my playlist accoding to this. However I do not have BPM in Spotify, therefore I need to create them within DJ Pro. Any update when this will be implemented?
