Will djay 2/pro ever be able to play songs from Apple Music, either streamed or downloaded locally?
I also had Apple Music. After trying Spotify i like Spotify much more then Apple Music. Ist same cost. Try Spotify, its better.
I also requested lokal mp3 files. But I found out that all locations I play have WLAN and this works without problems.
My Backup is a iPad DJay Pro with lokal MP3 Files.
Why would I want to do that? I don’t use Spotify. Tried it, hated it.
Hi Simon W Day,
we are not supporting Apple Music. Have you tried our Spotify integration?
Spotify rocks with DJay Pro----- its the only option so, its worth doing it
i do the exact same-- flawless! 40 million songs you can mix scratch and do anything too as if i own them all—DjayPro and spotify ROCKS!
