Will Mixon 4 work with new iPad Pro USB C?
I’ve posted a video, check it for info. Also, the iPad charges just fine.
I do indeed, here you go https://c.getsatisfaction.com/algorid…
Thank you for your response.
I have translated using google translate.
“New Ipad works with Mixon4 Using a USB-C to USB-B cable.
And is no longer connected via the iOS socket but directly via the USB port on the controller.
The result is that your IPad can not be loaded at the same time.
An update is probably planned by Algoriddim”
I’m not sure what you mean by this statement: “IPad can not be loaded at the same time”.
Please explain.
So the batteries will not charge?
Have you got a link to your video?
Thank you. But the topic is about the mixon 4 with a usb-c ipad. So the video does not help the topic starter.
This is not about the mixon 4 anymore. Unfollowing.
Same Question here, maybe if you use the USB-C Digital AV Multiport Adapter it will allow to charge the iPad (using the standard charger) and to connect to the Mixon using the USB port.
I don’t know if it will work, but if the new iPad works like a Macbook for connect devices using USB-C, it might work.
It’s not so convenient because you will need the ac charger connected, too many cables…
Hope Reloop works on some cable to connect directly to the port of the mixon4, like the lightning.
This adapter does indeed work as described on an ipad pro 2018 with the added benefit of video - cabling is clunky though so a usb c extender (0.5m and above) allows you to hide the cables and relieve cable stress on the ipad
Good evening, I own a Pioneer DDj We Go 3 and I have always connected my IPad Air 2 through the supplied IOS light cable … I have the original DJay 2 … with this connection my IPad is automatically recharged when the WeGo 3 is on and working … Last week I bought a 12.9-inch IPad Pro 2018 updated yesterday … unfortunately I can not connect it via the IOS Lightning cable … I connect it with a USB cable (from the WeGo 3) to the port of the new IPad with USB input C … Every command of the WeGo is executed but no longer recharges the IPad … can you help me please … is there an adapter? Do you have any information or links that explain why?
Thanks again … Maurizio
Ciao Luca, cosa intendi per AV adapter ? Hai un link o immagine da inviarmi per capire ? Al mio IPad Air 2 dalla WeGo 3 esco con cavo IOS originale ed entro in IPad Air 2 con cavo lightning… dietro controller WeGo 3 esiste anche una presa USB con entrata STAMPANTE ed appunto uso un cavo con quel tipo di innesto per andare al nuovo IPad Pro 2018 12.9 entrando con USB C… il tutto funziona leggendomi DJay 2 ma purtroppo non ricaricando il nuovo IPad Pro 12.9 2018
Grazie per la pazienza
Ciao Luca, infatti… questo adattatore me lo hanno confermato anche dall’ Algoriddim che potrebbe funzionare in quanto si esce dalla WiGo 3 entrando in USB (a dx della foto) e mettendo sotto ricarica l’ IPad Pro 12.9 col suo cavo (a sx della foto) Giustamente a questo punto andrebbe provato
Farò sapere una volta provato il tutto il risultato… se hai notizie anche tu, fammi sapere per cortesia… Saluti da Maurizio… Grazie Luca
Ciao Luca, l’adattatore funziona… la WeGo 3 con cavo USB (NO CAVO IOS INCLUSO) collegato a questo adattatore funziona e collegandovi il suo cavo ricarica l’IPad pro 12.9 2018 si ricarica allo stesso tempo… Grazie per il consiglio
saluti e buone cose da Maurizio
i am also interested - maybe with usb 2.0 b to usb c cabel? or usb c to lightning adapter?
I’ve got a message from Reloop Support (in german):
“das Neue Ipad funktioniert mit Mixon4 Mithilfe eines USB-C zu USB-B Kabels.
Und wird nicht mehr ĂĽber die iOS Buchse angeschlossen sondern direkt ĂĽber den USB Port am controller.
Folge ist aber das dein IPad nichtmehr gleichzeitig geladen werden kann.
Ein Update ist wohl von Algoriddim geplant.”
The batterie is not loading
