I took your advice and removed the Windows update that installed on my PC few days ago and it has actually solved the issue. I’m still concerned however that future windows updates may have the same effect on the software.
Bad news to report on my end. I was able to revert to Windows 24H2 while keeping my data in tact, but unfortunately the problem is persisting despite this. Perhaps I missed some follow-up steps? Any recommendations here?
Edit: I considered the possibility of this being a hardware issue, but the FLX6 worked completely fine when tested on Djay Pro on the iPhone 15; so this isn’t the case.
I’m noticing that the MIDI error in Windows 11 25H2 manifests itself differently depending on the hardware.
I have a Pioneer DDJ-REV 7 with Windows 11 25H2 (ARM version), and the problem I’m getting is with the turntables. The turntables spin at their normal speed, but the audio sounds incredibly slow; the song plays at 20 BPM.
However, on another PC I have, with Windows 11 25H2 x64 and a Ryzen 7 7000 series processor, everything works perfectly; I don’t have any problems. On my Windows 11 ARM PC, which is giving me MIDI problems, I did a clean install. The big problem is that during the Windows installation, all recent updates are automatically installed, but when I go to the updates menu, it says there aren’t any installed.
this is the exact issue I’m having with my Rev 5. I noticed it matches the tempo fader resolution of internal mode if you use a mouse to slide the tempo slider on screen. Could this be related somehow? @Slak_Jaw
EDIT - Uninstalling specifically KB5077181 fixed this issue for me completely on my controller, but the onscreen controls with mouse still function at a .4% adjust increment on 25% pitch mode. Maybe this is somehow related in some weird way.
Microsoft has released a targeted fix for issues with the new Windows MIDI stack. They are planning to roll out this fix to all users in April/May, but have made it available for download/installation as a short-term fix as well (see link below).
