Windows setup guide: 2× XDJ-1000MK2 + DJM-900NXS2 with djay
I’ve just finished getting this setup working properly on Windows, so thought I’d share the configuration in case it saves someone else some time.
My setup
  • Windows PC
  • djay Pro
  • 2× Pioneer XDJ-1000MK2
  • Pioneer DJM-900NXS2
  • Powered USB hub
  • RCA from each XDJ to the DJM
Connections
USB:
PC → powered USB hub → both XDJ-1000MK2s
My DJM is also connected to the hub via USB, although the DJM USB/ASIO audio driver is not used for audio in this setup.
Audio:
Left XDJ RCA → DJM Channel 2 LINE
Right XDJ RCA → DJM Channel 3 LINE
DJM Master → speakers
djay Pro Audio Settings
Go to:
Settings → Audio Devices
Set:
Audio Driver: WASAPI
Mixer Mode: External
Deck 1: Speakers (XDJ-1000MK2)
Deck 2: Speakers (2 - XDJ-1000MK2)
Deck 3: None
Deck 4: None
Pre-Cueing: None
I’m using a 256-frame buffer. If you get crackling or dropouts, try 512.
Important: I initially tried the DJM-900NXS2 ASIO driver, but this caused problems in djay. WASAPI with each XDJ acting as its own audio output has been completely stable for me.
XDJ Control
Go to:
Settings → MIDI Devices
Both XDJ-1000MK2s should show the built-in mapping:
Pioneer XDJ-1000MK2 (built-in)
I didn’t change any of the MIDI mapping.
Assign one XDJ to Deck 1 and the other to Deck 2.
The following all work:
  • Browse and load tracks
  • Play/Cue
  • Jog wheels
  • Tempo sliders
  • Sync
  • Hot Cues
  • Loops
  • Beat Jump
  • Quantize
DJM Settings
Set:
Channel 2 input → LINE
Channel 3 input → LINE
The DJM then works as the actual hardware mixer, including:
  • Channel faders
  • EQ
  • Headphone CUE
  • Sound Color FX
  • Filter
  • Beat FX
For the bottom crossfader:
CH2 Crossfader Assign → A
CH3 Crossfader Assign → B
If either channel is set to THRU, the crossfader won’t affect it.
DVS
Go to:
Settings → DVS Setup
Turn:
Digital Vinyl Control → OFF
It isn’t required for this setup.
Power-up order
This has given me reliable USB detection every time:
  1. Powered USB hub ON
  2. PC ON
  3. Wait for Windows to fully load
  4. DJM-900NXS2 ON
  5. Both XDJ-1000MK2s ON
  6. Wait around 10–15 seconds
  7. Open djay Pro
  8. Speakers ON last
I tested a full shutdown and cold start afterwards and both XDJs reconnected correctly without changing any settings.
Final signal path
djay Deck 1 → Left XDJ → RCA → DJM CH2
djay Deck 2 → Right XDJ → RCA → DJM CH3
This gives you djay Pro for library/deck control while still using the DJM-900NXS2 as a proper external hardware mixer.
Hopefully this helps anyone trying to get the same combination running on Windows. It took a little trial and error, but once configured it works really nicely.
Hi @LJ123, welcome to the Community! Very nice - thanks for sharing your detailed setup here.
Small extra tip – “Right/Left deck protected” pop-up
If you get a message saying:
“Right deck protected”
or
“Left deck protected”
when trying to load a track, it’s caused by this setting:
Settings → General → Protect active deck
When this is ON, djay stops you from accidentally loading a new song onto a deck it thinks is currently active.
That’s useful as a safety feature, but if you’re using the XDJ-1000MK2s as proper hardware decks and find the warning annoying, you can simply turn:
Protect active deck → OFF
I’ve turned it off on my setup so loading tracks from the XDJs is quicker and behaves more like a normal standalone workflow.
Thanks for the additional tip @LJ123
