I’m trying to use the Windows version and some of the shortcuts don’t appear to work. It seems like it’s all those that use the Alt key. Anyone else have these issues or similar? I am trying to use the Instant FX shortcut which shows as Shift+Alt+1 (for example).
Also, is there a keyboard shortcut to bring up the shortcuts screen/view as per the iOS version?
