Recently bought DJAY current version for MacBook Pro. Wondering If I can use my Hercules Universal DJ controller with DJAY? can’t seem to find anything online to point me in the right direction.
you can see all supported controllers here:
https://www.algoriddim.com/apps
Unfortunately the Hercules Universe is not supported.
Hi Wesley,
yes, you can use Universal Dj with DJay on the Mac (!)
I made a good working Midi file for the Hercules Universal DJ that works well with both DJay and DJay Pro.
You can download it free at my website: http://www.bayer-edv.de/clients/hercu… including a detailed readme about my optimizations
Feel free to give me a reply
It works also on iPad!
Go to iTunes. Connect your iPad and go to ‘Apps’. In Djay 2 or Djay Pro you add the midi mapping file in the documents of the app.
First download the midi mapping file on your pc, by the link above.
Hi Marini, thanks for the instructions for getting DJay iPad app working with Hercules Universal. So will this allow me load in Spotify songs into the DJay iPad app and control them via the Hercules Universal DJ controller?
