Workflow for creating stem loops?
Not able to find much on thus subject nod in currently finding the process far too time consuming.
Any tips?
Objective is…
Split a track into stems.
Create 8, 16, 24 or 32 bars
use logic pro for iPad to trigger loops (others would no doubt typical use abelton but i‘m trying to stick with iPad)
Create unique arrangements live.
Sync to djay pro or other using abolition link.
To be clear though the bottleneck is creating loops from the stems.
Hi @N_C,
Thanks for the question!
Are you looking to use inter-app audio between logic pro for iPad and djay for iPad for the triggering process?
Would you be able to provide any additional details that might clarify your request a bit?
Create 8, 16, 24 or 32 bars from stems.
Im looking fr tips on speeding up this process from anyone who has done it. That is all.
Thans
