- Device model (e.g. 2020 iPad Air 4th Gen): Ipad Pro 2022
- Version of operating system (e.g. macOS 14.4.1): latest
- Version of djay (e.g. 5.1.2): 5.1.6
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): N/A
Summary of the issue:
When adding an apple music track to a DJ pro collection playlist it is tagged as Tidal.
Because Tidal change their terms not allowing to mix streaming services I cannot add anymore tracks.
Please note that I used to have Tidal/beatport but switch recently to Apple Music/beatport. So I have the same playlist in apple music that in Tidal. But I disable Tidal entirely so there is no reason whatsoever the added track should be tagged Tidal. It is possible though that I have old session/playlist from DJpro with the tidal same track which could cause the issue when adding the same track but from apple music in a new playlist.
This is blocking me from creating new playlist
How to reproduce the issue:
Well I woudl create a playlist with tracks from Tidal
Then remove/disable Tidal
Create a new playlist and add the same tracks but from apple music.
See if the tags are Tidal or Apple.
Please note I cannot test this as I stop entirelly my Tidal suscription
