Hi! I will be playing in the club next week, but have a problem. Setup is DJM-2000 and XDJs-1000. All of these Djay Pro doesn’t support. Can’t install the driver DJM-2000 because of Big Sur. Only way is custom mapping of XDJ-1000?
Mac M1 Big Sur
Djay Pro 5.3.0
Hi @explash, the XDJ-1000 is natively supported for djay on macOS. That mixer is not supported, but you should be able to simply use it as an external mixer while using the XDJ-1000s as MIDI controllers connected to you Mac via USB.
Connect your CDJs/XDJs directly via USB and djay Pro for Mac will automatically recognize them and guide you through the setup. You can use each XDJ as a standalone controller including audio interface or you can use them in combination with a separate external audio interface for output.
For more info, please refer to section 5.17.2 of the macOS user manual: https://help.algoriddim.com/hc/en-us/sections/10663838083612-User-Manual-for-djay-Pro-on-Mac
what about xdj-1000 mk2?
Unfortunately, the XDJ-1000 MK2 is not supported.
Use Rekordbox to export your music onto flash drives and play from those directly on the XDJs.
