I have installed the mapping, my XDJ-RX reacts to the day Pro software e.g. dials move on the software etc but it doesn’t seem to be coming up an option to output on the XDJ-RX. The music doesn’t load in to the deck but the XDJ-RX can control the software… strange.
Ok I’ve purchased the software and the problem is still the same… I can’t use it at all through my speakers plugged in to my XDJ-RX. The output doesn’t have the option to use the PIONEER XDJ-RX like in above photo? Merry Christmas but please help lol
Well I’m on 2.10 but I’m trying to update to 2.20 and it’s not really letting me. I don’t know if the update will fix my issue but I’ll try get it up to date and see whether that fixes it with a firmware refresh.
Sorry I misread your message. I updated the drivers and it worked! I now have the XDJ-RX as an output. Brilliant! Thanks your help, such a simple thing to.
It works best with the XDJ-RX in “XDJ-RX-Mode” -> Change setting in “UTILITY” (longpress “MENU”) and djay Pro in “External Mixer Mode”. If no sound; could be that you’ll have to turn up once the volumesliders for ch 1 & 2 in the software itself.
Only thing that might seem weird in the mapping, is that “DELETE”, “MEMORY”, “JOG MODE” and “VINYL SPEED ADJUST” (also in combination with “SHIFT”) are used for FX 1, 2 & 3.
Any complaints or suggestions are welcome.
O and +1 for native support!
It would be awesome if it would work just like with the XDJ-1000’s. And as the XDJ-RX is one of Pioneer’s best selling djay-gear at the moment, there probably will be quite a lot of happy potential djay Pro customers.
