I just bought the XDJ-RX2 and I really hope it’s compatible with the Djay Pro Ai. Can you confirm that?
Best regards
Best regards
Works with Mac OS/MacBook (performance pads LEDs don’t work), but not IOS/iPad
Check under algorridim web site under DJ Gear/supported midi controllers.
Hi @Tobias_Martin,
Thanks for joining our Community.
This controller is natively supported on djay PRO AI for Mac. Please note it’s not supported on djay PRO 2.
Let me know if you have any further questions. We are always happy to help.
Cheers, G
