Any help or advice greatly appreciated, using djay for few years now on re loop mixon 8, want to upgrade to Pioneer XDJ RX3, is it now fully supported with latest update? Can I connect iPad directly to pioneer?
Hi @Ray-PlanB,
Thanks for sharing your question.
Currently, we cannot speak on this topic as the controller is not supported in djay for iOS.
However, we’d love to hear from other users as to what feedback they may have regarding this thread.
Can the rx3 now be mapped to work with iOS / iPad? There is a comment from you on another thread to say it is now supported? So I’m a bit confused?
@NathanielAlgo I’m considering swapping my Mixon 8 for the Pioneer Rx3 but just want to be sure it works with iPad.
Anyone using this combo / RX3 + iPad/Ios?
Is it working and Midi - mappable?
Hi @turbopussy, I think the RX3 is MIDI Class Compliant, but not Audio Class Compliant. So you might be able to MIDI map it on iOS, but the audio probably won’t work.
