XDJ-XZ functionally useless since last update/patch
So since the last XDJ update and last djay update all the midi mapping is incorrect, IE the crossfader manipulates Track volume, none of the eq knobs work, tracks will play continuously, volume faders do nothing.
What’s going on? Venue had CDJ 2000 and it worked just fine.
Yes I have external mixer setup, yes I have the correct channels added. This is straight up not working.
I don’t want to switch to rekordbox or serato but this isn’t the first time this happened to me.
Hi @CBJthedream, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Also, can you please confirm that you are using the Built-in MIDI mapping and not a custom edit?
Latest djay pro update
iOS (latest)
Xdj (latest)
Everything is updated
@CBJthedream provide the exact version numbers please. If you would like us to help you troubleshoot this issue, we need the exact details of your setup so that we can try to replicate the specific issue you are experiencing. Issues can be related to OS version, firmware version and djay version combinations. Thanks!
I suggest you check your settings. Specifically cross fader fusion effects.
Hi @CBJthedream, please try the following:
  1. Make sure UI line faders are up (since the XDJ XZ runs in external mixer mode)
  2. Make sure CFX are OFF
Hello! It’s been more than 7 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
