Hi friends … I had a question … today in 2020 is it possible to get xdjrx to work with djay pro? I looked at the forums, I did not find the solution to configure “audio device”, and to have the 2 operational decks, and that everything works correctly. does anyone succeed here? thank you for the feedback .
Hi @Adrien_Noia,
The XDJ RX and XDJ RX2 are natively supported by djay Pro for Windows as stated on our Hardware Page.
Please note that pre-cueing via the controller is not supported, but headphones can be used via the PC’s built-in audio output.
Hi Lukas , thanks for reply… I have a problem … I have all the sound on deck 1, deck 2 can control dj pro, but the sound goes only to deck 1 .can be an adjustment to do?
it works Lukas! I needed to put the xdjrx in midi mode, in the settings … yes I know … I’m a beginner …
