Xone:24C Mixer Official Support
@Mister_Tuur Where did you order the mixer and when is it supposed to arrive?
I’m in Germany. Should be here first or second week next month…
@Mister_Tuur Ich auch. Habe bei Thomann bestellt. Angeblich bekommen die den 24C erst Mitte Dezember.
Okay, not sure if you’d like to cancel your order, but I’m pretty sure I found a better deal (419). PM me in case you’re interested. :+1:t3:
+1 Following up here
Hi @koochey, welcome to the Community! Thanks for your input.
Has anyone received the 24C yet and tested it? I’m still waiting for the delivery.
  • 1
    Anyone received it?
Can someone test it on windows when received?
No. Maybe on 20. December
Xone 24 C work perfectly with DJ pro with serato time code ! i tested today on my ipad m3 !
https://www.youtube.com/shorts/jt4N_3t4OCg
Welcome to the Community! Thanks for sharing @Zlatin_Simonoff
G’Day Mate, My Brother just got one and you can manually map it. i did it for him with Djay’s very easy Mapping system. we had the 24c used as a mixer for 2 Decks and a K2 used for transport controls, FX, Library navigation and also Stems. i am sure it will be supported soon but being only 2 channels it will take you 2 minutes to map.. or i can send you the mapping
Thanks for sharing @JC_Records
Did you setup Djay DVS on the Xone 24C with mac or windows?
@JC_Records
Could your share / send the mapping? Thanks.
Hi Mate, (Windows 11 Home 25H) No DVS, we use the 24c as a standard 2 channel mixer and have the K2 running through XLink and then use that for everything else. Like transport controls play/pause, Sync, Cue etc. and then whatever else we want.. if you have a 24c its a great addition to have the new K3 is exactly the same.. i have a few different mappings for those too.. with the 24c it has 3 different Modes accessed like this..
To change modes you turn the mixer off.. hold down channel 1 and 2 cue buttons. Turn the mixer on while still holding the cue buttons for 3 seconds. Release and the Aux channel cue button will flash rapidly..
press button for mode
Aux filter = Stream Mode
Ch 1 filter = DVS Pro Mode
Ch 2 filter = Daw Mode
Daw Mode is the one you want so it sends the MIDI signal so you can map the 24c how you want it.. and Use DVS pro if you are using Control Vinyl.. i will set up a Git Hub Repo and put all my mappings and info in there for everyone to share and contribute.. Stand by.
Hey Mate, will set up a Git Repo and put all my mappings on there
I’m a fairly technical hard & software guy, but I’ve never owned a ‘classic’ mixer like this with midi out. So I sort of don’t get what happens when you e.g. map your EQ knobs.
I get the out midi part so you can map it to anything you want on the software side, but that doesn’t disable the hardwired EQ on the mixer, right? Or does it? But what’s the use if it doesn’t?
Somehow this is nowhere to be found in the docs. Must be really straightforward then, but I don’t get it.
I’ll figure it out in a week or two anyways, but still…
Hi @Mister_Tuur, the device will still be used in External Mixer Mode so the EQing is done within the hardware. The MIDI simply allows the onscreen controls to match what the hardware shows.
Ah. Of course. Cheers!
