That’s a real shame. I specifically ordered the Xone 24C to use the audio interface via USB and not the LINE input, because of the poor sound quality through the MacBook’s headphone output. If Djay doesn’t support the 24C in the future, I could have just bought the Xone 24, without the USB interface.
@Mister_Tuur Are you sure that it will work as an audio interface because it is class compliant with macOS, iOS etc. My 24C will arrive in December.
" 8. USB HOST-Port
USB-C. 12 Channel (3 Stereo IN/3 Stereo OUT), 24Bit/96kHz, internal Hi-Speed USB soundcard. macOS / iOS class compliant. ASIO compatible. Direct, full-duplex MIDI connection."*
#### Apple® Operating Systems
The Xone:24C features an Apple CoreAudio and CoreMIDI class compliant interface that will work on macOS® iPadOS™ and iOS platforms without any requirement to install hardware device drivers.
Source: https://support.allen-heath.com/hc/en-gb/articles/39821017822865-Xone-24C-User-Guide
Which DJ mixers are supported on djay Pro for Mac?
Generally, every USB audio mixer is compatible with djay Pro for Mac. If your DJ mixer is not class-compliant, you need to make sure that you’ve installed the necessary driver to run audio through it. If you have any audio issues with your mixer, please make sure to check the "I can’t hear any audio through my master/pre-cueing output" section in our Controller Troubleshooting Guide.
When you connect your mixer, djay will automatically detect the device and set it to external mixer mode. You can always double-check this mixer mode was chosen correctly in the Devices tab in djay Pro AI’s Preferences (⌘+,):
https://help.algoriddim.com/hc/en-us/articles/4405514721682-Which-DJ-mixers-are-supported-on-djay-Pro-for-Mac
How do I use an external mixer with djay Pro for Mac?
You can connect djay Pro for Mac to any compatible external mixer. By following these steps, you will assign the djay-deck outputs to different channels of your external mixer.
- Connect your mixer with your Mac via USB. If the mixer requires a driver, make sure it’s installed.
- Go to the djay Pro “Preferences…” (press ⌘ + , ) and select Devices.
- Now switch to “External” and assign the decks to the mixer, as shown below:
https://help.algoriddim.com/hc/en-us/articles/360014912271-How-do-I-use-an-external-mixer-with-djay-Pro-for-Mac
The Xone 24C’s audio interface is class-compliant with macOS and iOS, and you state on your website that any audio interface is compatible (see links).
@slak_jaw So I don’t understand why you say it wouldn’t work?
