Xone 24c post fader FX
Hi all
As above, does the new Xone 24c have post fader FX, particularly when playing real vinyl with Djay Pro in thru mode?
Hi @STU-C, you can enable Post Fader FX in the djay Settings>Sound.
Thank you, and will that mean you still have to have the channel selector in USB mode then run the record through the software? or will the software work in say phono mode on the channel selector?
I guess its an audio routing question.
You’re welcome @STU-C. Unfortunately, I’m currently on vacation and don’t have access to this hardware to confirm. I recommend you reach out to our official support team from within the djay app to answer this question.
stu-c i think i can help
the xone24c doesn’t have an effects routing not in the same way as like a numark scratch or a pioneer s5
it just has a master fx insert
Thank you, A&H replied to me on YouTube to confirm the same. I’m waiting patiently for the next generation of scratch mixer to release. USB-C and FX are a must.
Thanks for sharing this info @owlnotebook
Got another brainwave…
Thanks for linking to this suggestion @Mister_Tuur
