Xone 96 and stem / FX control
Hi All,
Sorry if this is a dumb question firstly.
Is it possible to map any of the buttons on the Xone 96 to control stems and FX if so how using and ipad?
Cheers in advance
Hi @Edg1983, I don’t have access to a Xone:96 to confirm for myself, but given that this hardware is supported on iOS, it’s most likely MIDI class compliant. So, you should be able to customize the MIDI mapping to your liking. For more on how to use the MIDI Learn tool in djay, please refer to the linked FAQ below:
https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
