Hello, i’m studying the xone:96 mixer integration with djay pro.
There is no rotary with on the xone available to midi mapping according to https://www.allen-heath.com/content/uploads/2023/06/X96_MIDI-Control-Overview.pdf
How it possible to launch browser, navigate and loack track without having rotary midi ? Can we open browser, do next track / previous track with click of a midi button ? and then load ?
THanks for your help
Hi @ndmind1 , yes, you can definitely MIDI map these functions to buttons instead of a rotary control.
Please refer to this FAQ article regarding MIDI Mapping on iOS: https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
Start by simply pressing the button that you want to map to Library controls.
Set your Target to Music Library . You will find all of the Actions you need within this sub-section.
Now set the Action to the desired MIDI Command like Toggle Library Expanded .
Thank you very much for your clear answer.
You’re welcome @ndmind1 . Happy to help!
system
Closed
June 29, 2024, 3:02pm
7
