Sometimes, you actually feel like mixing.
Mixing on tiny faders (like on the Numark DJ2GO Touch for example) is a pain because you can’t get granular with your mixing. You are forced to use Sync.
Mixing by ear is essential for mixing tracks with live drummers, I know that sounds antiquated, but it’s an acquired taste, like driving stick.
Yes I agree, and this should be trivial to add…for using the iPad screen directly and controllers even with somewhat large pitch controls (Mixon 4) it is hard to manually set the pitch…especially around the center dead zone which I don’t think we have the option of controlling.
I would even suggest a 2%, mode while we’re at it, honestly.
Just wondering if this was still being looked at? Because using e.g. a Numark DJ2Go2 Touch (but I’d guess the Hercules offering has similar problems) - +/- 8% is quite a wide range for a very small slider!
