Add a Search Bar specifically for Playlists
Hi DJay Team,
I’m a proffesional mobile DJ that works in Weddings and a varaity of events.
My library is big and i have MANY diffrent playlists.
Some features that i’m sure will help many djs like me, order by priority (IMO):
  1. The ability to Search for a Playlist
    To have a small search bar above the playlists list and to be able to look for a specific playlist. God knows how much this is needed haha. Please!
An Example From Lexicon:
Would literally improve my Djing and my life in general ngl!!!
Hi @Alon_Sharir1, thanks for the feedback and suggestions. Please break each of these out into their own Suggestion topics so that other users can upvote them individually and we can properly track each one. Thanks again!
EDIT: Also, I found the following existing Suggestion, so please move your comment above to it and cast your vote over there:
#2 Introduce a Song Playlist Favorites Bank
#4 This is already possible by enabling the correct menus. I’m showing the Windows version as an example, but it’s pretty similar on macOS.
Hi @Slak_Jaw, thank for replying !
I changed the topic so maybe change the solution status?
Will do about #2
About #4 -
I would argue that this specific place is not only hidden to get to, but it takes A LOT of unnessecery space in the UI.
Maybe adding it the the pace that i suggested can save up that space.
You’re welcome @Alon_Sharir1. Happy to help and thanks for the additional feedback. I have passed this onto the dev team for consideration.
Can there be a playlist “search” function for Tidal like they have on the app?
Hi @E_Flem, I’ve merged your new topic with this existing one as I believe they are closely related. Thanks!
Thanks, I used Tidal because it already had a search algorithm that would probably be more easier to implement.
Can you please add playlist search like Rekordbox and Serato has. Thank you!!
Hi @Mac_Joseph, please use search before creating new topics. I have merged your new topic with this existing one. Thanks.
Just commenting to share how great it would be if we could search for our playlists! Much needed, and Serato will have it in their upcoming update. Thanks team!
Thanks for the feedback @djmikelujan
Almost like the poster predicted this. Upvoted already.
I actually had thought this feature would be included in the “djay 5.6 Major Update”
Thank we need playlist search!!! ASAP!! We hate scrolling just to find one playlist buried in our playlist section! This will save lots of time when DJing on the fly. Thank you!! :folded_hands:t5::folded_hands:t5:
Thanks for the additional feedback @Mac_Joseph
Hey @Slak_Jaw
We also need a “playlist bank,” where you can store playlist from streaming services, for that specific event. Maybe 10 playlists per streaming service, or more. If you got 80 playlists, having a dedicated bank can be helpful.
Thanks for the additional input @E_Flem - I’ve passed it onto the devs.
be nice to have crates or folders you can add Tidal playlists to,
like a rock folder, you can add all your rock Tidal playlist to, it helps minimise all the playlists into sections you can easily find what your looking for, especially when you have so many playlists in tidal.
Spotify has folders their app but it would be nice if DJay Pro could have it too.
