Add Neural Mix to Apple Music Streaming
I would love to see Neural mix feature available with Apple Music, it is one of the main edges of DJay Pro AI.
As much as I and everyone using Apple Music is agreeing with you, the limitation is with Apple Music themselves and not with Algoriddim,
Is there any type of negotiation to make it available in the near future? I believe it would be an amazing feature that would allow DJ Pro AI to fully function and could even help them sell Apple Vision, for example
If they did you will probably see a price increase as Tidal have done.
It used to be £10.99 but now they have introduced a DJ subscription which you have to pay if you want to use it in Djay. It includes stems and it’s £19.00 a month
Thanks for the suggestion @Alex_B. I’ve sent this to the dev team for consideration.
there’s already one service providing stems, Tidal.
from all I’ve read it’s the next biggest competitor
why not use that??
Tell your Apple partner to do the same DJ option than TIDAL :slight_smile:
Apple Music DJ subscription that allow stems like Tidal DJ
and wake up : This 17/4/2024 : Rekordbox/Serato/Virtual DJ (in their latest updates) allow TIDAL stems with TIDAL DJ option and DJAY PRO still nothing.
And read lyrics .lrc TIDAL/APPLE MUSIC and local music in DJAY VIDEO mode
Regards,
Olivier
If you check the forum messages you will see that Algoriddim have updated DJay, but the delay is caused by the software stores.
Other companies provide downloads directly from their sites, but they only cater for PC and Mac.
@Olivier_Frappier please use search before creating new topics. I’ve merged your new suggestion with this existing one. You can cast your vote here. Thanks!
I agree because it make the transition a lot smoother
I want to know if there is still no solution for the pop up message: [“Neural Mix Cannot Be Used When Streaming From Apple Music” Due to licensing terms this feature is currently not available on this streaming platform… I’ve tried everything and still, I can’t use neural mix functions with apple music streaming. Is there a current solution?
The solution is that Neural Mix functionality is not available with Apple Music streaming due to licensing lol. Only Tidal with the DJ extension has stems with streaming, I believe.
As well as SoundCloud, Beatport, Beatsource and Djay Music.
Hi @santiago09, welcome to the Community! I’ve merged your new topic with this existing suggestion. Please note that this needs to be allowed by the service provider before we can implement it in djay. As others have noted above, there are some other streaming options available that do permit the use of NM. I hope that helps!
so no chance this happens?
There is definitely a chance this will happen, but it is largely out of our control at the moment. For reference, NM was originally blocked when using Tidal, but has since been unlocked by the service provider. The same could happen for AM at some point, but we don’t know when.
DJay Music?? What is that?
@allentastic, this is the free streaming service provided by Algoriddim.
