Adding midi controller to Mixon 8 set up.
  • Device model: iPad Pro 11”
  • Version of operating system: ?
  • Version of djay: 5.1.4
  • Hardware/controllers used: Mixon 8
I would like to add a small midi controller to controller neutral mix.
Am I able to plug the controller into one of the usb ports on the Mixon 8? Can it act as a hub ? Or do I need to add a hub and plug in the iPad and midi controller into the external hub ? At the moment I love the fact that I can use 1 usb c cable for data and power for the iPad.
What small midi controllers would you recommend?
Hi @Nubium, you will need a USB hub connected to the iPad. You cannot connect the second MIDI controller to the Mixon 8. I use the Midi Fighter Twister and Spectra for Neural Mix. See my personal MIDI mappings linked below:
