DJ TechTools Midi Fighter Spectra - Neural Mix / Serato STEMs Mapping
This is my answer to all the hype surrounding the new Serato STEMs implementation. Banks 3 and 4 use a combination of Instant FX and Neural Mix to achieve a similar result to what Serato is doing.
The mapping files are stored on DJ TechTools mapping site: DJ TechTools - MidiFighter Spectra-Djay-Neural Mix
Please make sure to import the Midi Fighter Utility file included in the ZIP file so the side buttons and LEDs work properly.
Most buttons have a Shift layer and are shown in Orange in the mapping key.
For the Neural Mix Instant FX 5-8 you can select your own options for Drums and Vocals within Djay, but these are the settings that I found work best:
To change the Instant FX settings in Djay do the following:
  1. Switch to Instant FX mode
  2. Select the pencil icon in the top right
  3. Select the 3 dots next to the FX you want to change
  4. Scroll down near the bottom in the Neural Mix section and select the desired Instant FX.
Here’s the MIDI Mapping Key:
is it possible to get this mapping as well? I can’t seem to get it on the DJTT website. just pulled my spectra out from a few years ago. thanks!
Hi @Inferno765, welcome to the Community! I’m currently on the road and don’t have my Spectra with me to check, but I did find this Spectra mapping on my phone. You could give it a try.
MF Spectra - SJ1.0.djayMidiMapping (46.8 KB)
