Advanced Pro functions on Android
Here it was mentioned that Android can’t handle the Pro versions Neural Mix.
I only have Android tablets and recently obtained Reloop Buddy. I would like to buy the same software The Apple iPad iOS or most recent has. So is it true that Android tablets don’t work very well with djay Pro and I should buy iPad or Mac computer just to use advanced functions? Where to get discount then in Finland? For bedroom use I think iPad price is too high but I wanted to use the max 48 loop looper…
Should I wait update for Android? In Finland Android (Lenovo, Samsung etc) is more popular than Apple iPadOs.
So do I wait update to Android or try to get iPad on discount ?
Antti, Finland
The link Neural Mix for Android
