Album artwork not fully covering
  • Device model Samsung S24 Ultra:
  • Version of operating system Android 14:
  • Version of djay (5.2.8):
  • Hardware/controllers used DDJ-FLX4:
Why is my album artwork showing so small on the turntables instead of fully covering the wheels?
Because the turntables represent vinyl, and vinyl records have the label in the centre, not over the entire record.
But before and on my old phone the pictures cover the whole jogwheel… its nothing but i like it:)
Anyone have the answer??
@jacquesnl don’t listen to @PKtheDJ, he always want to be smart and explain he’s own broken mind
just Go settings/appearance/vinyl/style: Picture disc
So you had to switch the style to picture disc, which of course does cover the entire disc.
That’s exactly what a picture disc is. What I said earlier is accurate. If it’s not set to picture disc then the label will be in the centre because it represents standard vinyl.
That’s an accurate description, not “broken”.
Im talking about android. Does not have that setting
According to the manual it does.
Your not helping mister
I don’t use Android. Check the manual or check the settings. It should be there.
Its not in the settings everybody knows
This video shows it’s possible on Android (look at the decks).
Lol i said it is working on my old phone…
What’s funny? You say the setting isn’t there, but:
  1. The manual shows that it is
  2. The video shows the devices using that mode
  3. Your old phone is set correctly
If it’s not in the settings, how have they achieved it in the video, why is it mentioned in the manual, and how is your old phone doing it?
Change the setting on your new phone to the same as the old phone.
Please say nothing dude
Be nice my friends. We all have our frustrations.
We are here to help🙏
Hi @jacquesnl, please try navigating to the djay Settings>Appearance>VINYL and turn ON Show Full Artwork (Picture Disc). Below is a screenshot from iOS, but I think it should be similar on Android.
Nope 1000% sure i even tried upgrading to pro
Thanks for confirming @jacquesnl. Can you please share some screenshots of these settings in djay?
