Hello dear community,
Does anyone had experience with iPad pro with djay Pro AI and Allen & Heath Xone 96 mixer ? Does the xone work as audio interface great or completely not?
According to the gear page Xone:96 is supported…
Hi @Mateo_Paz,
The Allen & Heath Xone:96 is indeed natively supported as pointed out by @nso (thank you by the way!) and also works in a DVS setting as well which is represented on our DVS page found here.
Works great with Xone 96. I’ve played out a couple times with it!
Does the xone 96 send midi signal on from the eq knobs?
Do the 4 audio channels work in stereo? That would be great. 44k, 48k, 96k? 16bit 24bit 32bit?
I have a setup with a Pioneer djm750MK2 and a macbook but I would like to change it for a xone 96 with an iPad.
Xone 96 has a Dual 32-Bit 24 Channel Soundcard
96kHz/32-bit processing ensures the highest audio quality is passed between your laptops and the analogue engine! I hope this help to decide!
But can you use all its channels at the same time with an iPad?
yes you can use all the channels at the same time of course!
Dear all, I cant manage to use the DVS mode with my iphone on the xone 96, mixer is recognized, TT’s are plugged phono on lines 1 and 4, but no signal to calibrate the records, internal mode works but I guess my routing is wrong, pkease help !!
Ah and I use 7" serato records, can it come from there ?
on input selector select USB 1
Select MIDI 1 (should lit in blue once MIDI active)
on back side, there is a tiny white button/selector, keep that Push In
Nice! Thanks for sharing this @DJ-Z. Very helpful!
Thanks a lot it works great !!!
