I would love it if the FX would get a tail when you turn them off, similar to when you pause a track while an effect is on.
I’ll use echo as an example:
Current behavior
When I turn off the echo effect, the effect is immediately gone, just as if I had turned the dry/wet dial all the way to dry.
Desired behavior
When I turn off the echo effect, the effect plays on with the input it had until that point, the same way as if I had left it on and hit “Pause” or turned down the fader.
Thank you for pushing the topic. As some users also want the on off button of the FX to immediately cut off the effect it would be interesting to get some more opinions on the topic. Also feel free to upvote the topic to push the conversation.
