Could it be possible to have aswitch that allows the FX to have tails once turned off?
for example, when using reverb or delay to create a build before a drop, or next section of song that the reverb or delay would finish out its fade over that new section, which would make the whole transition a lot smoother…
especially if your going from deck to deck…
maybe the FX should be routed int the master channel instead of the deck channel
this would be awesome !!!
add ableton link, AU VST FX integration and offline spotify and you cant be touched by any other app out there… oh and window pro 2 would be nice .
