Analyze Tidal tracks button don't work
Hi there. Just got Djing again (finally!!!), got Tidal up and running. But there is not possible to get the songs analyzed. The analyze button wont respond. Any easy fixes here?
Which dj pro app and version you are using?
In “old” djayPro 2 you need to use this trick
Hi. Using Djay pro 2 version 2.2.8 . Downloding AI now…
